NaturalEnquirer's avatar
Jun 13, 2016
Latest Firmware on WNDR3700 ver. 1
I have WNDr3700 ver. 1 router with firmware 1.0.7.98. If I check for fimware upgrade on router maintenance screen it says no updates. However I see on Netgear's WNDR3700 ver. 1 support page that it lists ver. 1.0.7.981.0.16.98 as newest firmware. Since router isn't detecting a firmware update, I just want to verify that this is correct?
  • Hi NaturalEnquirer
    Welcome to the community!
    Yes, the very latest firmware for WNDR3700v1 is 1.0.16.98.
    I will inform our engineers that it doesn't pick up the latest firmware using the auto detect.
    Thank you!
1 Reply
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi NaturalEnquirer
    Thank you!
