NamelessPerson
Aug 08, 2021Star
Latest update bug: R6400 Firmware DNS issue (V1.0.1.74_1.0.48)
This latest update broke DNS resolving, so it randomly cuts out and doesn't resolve anything. Random web pages will just error out. Connection to generic services won't work at all. More can be s...
- Oct 24, 2021
It's apparent that since the DNS problem arose, subsequent and unrelated updates have made the router(s) even worse. In fact, I think Netgear is imploding as we speak.
“Way to go Disney! I have disabled automatic updates because the last update from Netgear slowed my router down so much. I had to downgrade to a much older version that did not include the armour guard application to get my full isp speed back. I am afraid that this new patch will come with the same application that I had to get rid of that slowed down my router. Maybe it is time for a new wifi 6 router from a different company.”
“the same issue with the 6400v2 downgraded the firmware which helped get more speed but ultimately bought a new router the Rax50 to keep up with the speeds much happier now.”
Source: PCMag comments / Netgear forum
I do however have a solution to my issue; I bought a non-Netgear branded router. Are you looking for a router with stability, performance and industry standard updates that don't break the the product altogether? Look no further.
- Enjoy ultrafast speeds up to the advertised data transfer and WiFi speed rates
- Guaranteed DNS functionality
- Don't include blueprints by Microsoft listing amateur router exploits
Buy anything but Netgear today. Special thanks to olympos1625 for logging in the forum every day and ignoring everyone while having the time to respond to new threads. I hope everyone else gets a working router sometime soon because this is verging on class action territory when the product isn't end of life. Oh, how the mighty fall.
Buck_Rogers
Aug 14, 2021Initiate
I had the exact same problem as NamelessPerson.
And yes, I reset my router and that solved nothing except disrupted the home internet...I ended up reverting back to V1.0.1.68_1.0.43
And with that, the DNS resolving problem was resolved.
Please quickly fix the firmware so I can get whatever security issues were addressed.
dukdukgoos
Same issue. Breaking DNS in an firmware update is pretty facepalm Netgear. Be better!
- michaelkenwardAug 15, 2021Guru - Experienced User
Breaking it is bad, but not detecting the bug before release, and then not responding when the problem comes up here, is even worse.
Meanwhile, roll back to the previous version.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
