NamelessPerson
Aug 08, 2021Star
Latest update bug: R6400 Firmware DNS issue (V1.0.1.74_1.0.48)
This latest update broke DNS resolving, so it randomly cuts out and doesn't resolve anything. Random web pages will just error out. Connection to generic services won't work at all. More can be s...
- Oct 24, 2021
It's apparent that since the DNS problem arose, subsequent and unrelated updates have made the router(s) even worse. In fact, I think Netgear is imploding as we speak.
“Way to go Disney! I have disabled automatic updates because the last update from Netgear slowed my router down so much. I had to downgrade to a much older version that did not include the armour guard application to get my full isp speed back. I am afraid that this new patch will come with the same application that I had to get rid of that slowed down my router. Maybe it is time for a new wifi 6 router from a different company.”
“the same issue with the 6400v2 downgraded the firmware which helped get more speed but ultimately bought a new router the Rax50 to keep up with the speeds much happier now.”
Source: PCMag comments / Netgear forum
I do however have a solution to my issue; I bought a non-Netgear branded router. Are you looking for a router with stability, performance and industry standard updates that don't break the the product altogether? Look no further.
- Enjoy ultrafast speeds up to the advertised data transfer and WiFi speed rates
- Guaranteed DNS functionality
- Don't include blueprints by Microsoft listing amateur router exploits
Buy anything but Netgear today. Special thanks to olympos1625 for logging in the forum every day and ignoring everyone while having the time to respond to new threads. I hope everyone else gets a working router sometime soon because this is verging on class action territory when the product isn't end of life. Oh, how the mighty fall.
bouncdchk
Aug 15, 2021Initiate
Oh thank goodness it's not just me. I was going crazy cause I thought it might have been the new Windows update but my router updated at the same time.
I did a reset, tried setting the DNS manually to Google and Cloudflaire and still had the same issue. I was starting to think it was something else.
I finally rolled back my firmware to version V1.0.4.106_10.0.80 and that seems to have fixed my issue.
PJRyno
Nov 13, 2021Initiate
I did this on two separate routers and both are back to functioning without the DNS problem. Netgear - Please let me know when the new firmware update is availlable without this DNS problem. I wasted a lot of my time on this problem. Not happy about it!
- AbtjgNov 30, 2021Aspirant
Would appreciate it if you can advise how you got older firmware versions like this one from the support site? The oldest listed under, "previous versions" is 1.0.2.52 and I can't seem to get to anything older than this...
Rolling back only to 1.0.2.52 sounds like it would not fix this issue....
When I go to the Netgear support site, the oldest firmware version available is 1.0.2.52 which would not resolve this issue.
Any advise on how to get to even older versions (like to V1.0.4.106_10.0.80 which you mention) ?
Thank you!
- michaelkenwardNov 30, 2021Guru - Experienced User
Where are you looking?
The R6700 listed in your footer has firmware from
Firmware Version 1.0.0.2 (Initial Release)
Firmware Version 1.0.2.26
There is no V1.0.4.106 for the R6700 or for the R6400 listed in the subject of this discussion.
For the R6400 firmware goes from
Firmware Version 1.0.1.76
Firmware Version 1.0.0.14 (Initial Release)
Neither the R6700 nor for the R6400 has 1.0.2.52 firmware.
We seem to be getting off topic here. Anyone with a different device from the R6400 might like to start a fresh discussion.
That is not firmware for the R6400 listed in your footer.
They go from:
to
