bbaccutel
Jan 23, 2021Follower
LBK 1220 ORBI 4GK AC1200 MESH SYSTEM
Im unsure which router to choose based on my system. Im just trying to figure out why my system (Orbi) wont connect to certain sites when ran through my spectrum router (ASKEY model SACZVIK). Can someone please give me information since im stupid when it comes to this stuff?
1 Reply
> [...] why my system (Orbi) wont connect to certain sites when ran
> through my spectrum router (ASKEY model SACZVIK). [...]The exact meraning of "certain sites" is a little unsertain.
Generally, cascading multiple routers can cause multiple problems.
Is there a modem of some kind connected to the SACZVIK router? (What
_is_ connected to its WAN port?)If all your computers/devices are connected to the Orbi gizmos, then
you might want to remove the SACZVIK router and connect directly to the
Orbi WAN/Internet port.If you have computers/devices connected to the SACZVIK, then you
might want to configure the Orbi as a wireless access point. Visit
http://netgear.com/support , put in your model number, and look for
Documentation. Get the User Manual (at least). Read. Look for "Use
the router as a WiFi access point only".
