ekosanov
Jan 10, 2017Aspirant
LED's Not Flashing / Always On
It would seem all the LED's on the router have stopped blinking (always on with active connection) tho from what i can tell the router is working fine. I was reading a post for some other router and...
- Jan 20, 2017
I have checked this with engineering and they said that for this model, LEDs will not flicker when there's traffic.
So, it's normal for it to be solidly lit all the time.
ekosanov
The router is a WNDR4300v2
- ElaineMJan 13, 2017NETGEAR Employee Retired
Welcome to the community, ekosanov
If all LEDs are turned on even if there are no devices connected to it then I suggest that you replace the unit.
- ekosanovJan 16, 2017Aspirant
They are not on with no connection. Only always on WITH an active connection. The LED's do not blink when data is sent like the other 9 Netgear products i have.
The ACK signal is sent by the receiving station (destination) back to the sending station (source) after the receipt of a recognizable block of data of specific size.
In this case the LED's blink to show activity. The WNDR4300v2 LED's do not blink.
I'm not sure how i can make this any more clear other then go home look at your router..... are the leds blinking showing data is being sent?
Well my new router does not.- ElaineMJan 17, 2017NETGEAR Employee Retired
Did you try factory reset?
There are really no settings on the router to adjust and tell the LEDs to flicker when sending data.
It maybe just an isolated issue.
