ekosanov
Jan 10, 2017Aspirant
LED's Not Flashing / Always On
It would seem all the LED's on the router have stopped blinking (always on with active connection) tho from what i can tell the router is working fine. I was reading a post for some other router and...
- Jan 20, 2017
I have checked this with engineering and they said that for this model, LEDs will not flicker when there's traffic.
So, it's normal for it to be solidly lit all the time.
ekosanov
Jan 17, 2017Aspirant
Yes i did try the factory reset and did not help then i reinstalled the OS also did not help.
Next i tried a new router from the same walmart i got this router from and it does the exact same thing.
I'm thinking it may be a code omission in the firmware.
I'm just trying to confirm if its just my units or all of the WNDR4300v2's. If its just my units then a hardwhere problem if all units then its a firmware issue.
ElaineM
Jan 20, 2017NETGEAR Employee Retired
