SuperTweaker
Sep 01, 2015Aspirant
Less than 100mbps on WNR2000v3
My ISP has increased our speed from 105 to 150mbps down. I plug my computer directly into the router and only get 95mbps. When I plug directly into the modem I get 175mpbs, higher than the boosted ...
- Sep 02, 2015
You need a router with Gigabit Ethernet ports (and WAN port), which would be many of the routers that followed the WNDR3700 (my first gigabit router). Personally I would recommend the R7000 but there are plenty of cheaper models that would serve your purposes, you just need to ‘Google’ ‘Netgear gigabit router’ and you should find plenty of options.
Babylon5
Sep 02, 2015NETGEAR Employee Retired
All Ethernet ports of the WNR2000, including the WAN (Internet) port, are 10/100 capable only, so no data transfers that involve a wired connection to the router can exceed that rate.
- SuperTweakerSep 02, 2015Aspirant
Thanks Babylon5,
In the same room are two desktop computers, both are plugged into the N300 router and get 95mpbs. Two other devices, a Kindle Fire and a laptop use the secured wireless connection. Neither of those devices need more than 50mbps.
With the information above, what router would you recommend that has 10/300 in all four LAN Ports but is also a wireless router. I like Netgear and tried the N900. Only one Ethernet Port on that router allowed 175mbps. The other 3 are reduced by default. The wireless connection reached 40mbps which was fine.
- Babylon5Sep 02, 2015NETGEAR Employee Retired
Thanks for your help. BestBuy was having a sale on the N600 Combo Modem/Router. Just got through setting up. I am now getting over 150mbps on both Ethernet Ports and 50mbps on the Wireless. Easy setup, just had to contact Comcast to register/activate the modem.
Thanks for your help. Kudos!
