bmwatters
Jan 30, 2017Follower
Lightify doesn't work with Netgear R6220
OSRAM Lightify is a smart lighting technology that hooks up devices (lightbulbs, outlets, etc.) with a Gateway that plugs into an outlet. Ive tried connecting it numerous times and it hasn't worked....
- Jan 31, 2017
Hi bmwatters,
1. What is the firmware version of the router?
2. Please make sure that the gateway is among the connected devices to the router (able to get an IP).
3. Please make sure that you can ping the IP of the gateway.
4. If port forwarding is required for the gateway and you have the port numbers, you can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/24046
Dexter
Community Team
DexterJB
Jan 31, 2017NETGEAR Moderator
Hi bmwatters,
Dexter
Community Team
