WilliamSaylor
May 02, 2022Follower
Lightning strike
Lightning strike knocked out router. No power light and no network lights. Power does go into power supply board and it appears that there are two 12 VDC outputs going to circuitry - but no power lig...
May 02, 2022Guru - Experienced User
Lightening is great at wrecking electronics.
But you might have a matching power supply sitting around you could try. just make sure it has the same exact voltage and polarity. it can have a higher amperage but not lower.
Worth trying if you have one sitting around because its a pretty common size/voltage used in netgear routers.
