WilliamSaylor
May 02, 2022Follower
Lightning strike
Lightning strike knocked out router. No power light and no network lights. Power does go into power supply board and it appears that there are two 12 VDC outputs going to circuitry - but no power lig...
michaelkenward
May 03, 2022Guru - Experienced User
WilliamSaylor wrote:
Lightning strike knocked out router. No power light and no network lights. Power does go into power supply board and it appears that there are two 12 VDC outputs going to circuitry - but no power light. How likely is it that the power supply (MOV ??) is bad and that a replacement power supply is available?
Thank you,
Bill
If you are lucky, the lightning strike killed the adapter before it could reach the router.
Netgear does not sell replacement power adapters. Any generic adapter will work. Just get one with the right volts, enough amps and a tip with the right (+/-) polarity and dimensions to fit your hardware. Some adapters come with an array of different tips.
Generic adapter
The details you need should be on the old adapter, on a label on the device itself and in its manual.
You can find suitable adapters in all the usual places. Some will even list compatibility with different Netgear hardware.
