cm2297
Sep 21, 2015Aspirant
Live parental controls fails to setup
I have a N900 wndr4500v2. When trying to set up the parental live controls I make it as far as putting in user name and a password. I hit enter and it comes back with the password not being long enou...
- Sep 23, 2015
Can you verify if using a special character and capital letter for password will help you guys pass this registration?
Looking forward to your responses.
ElaineM
Sep 22, 2015NETGEAR Employee Retired
Hello cm2297,
Welcome to the community!
Is this for the bypass account or just simply creating the login for the Parental Control?
Can you post a screen grab of this window?
Did you try using a different web browser? Also, try deleting browsing history and clearing cache.
Looking forward to your response.
- buckeyestargazeSep 22, 2015Star
I have this exact same problem on a 7500 AC Nighthawk router. I get to the place in Genie where I try to setup a new OpenDNS account and it gives me an error that the password needs to be between 6-20 characters. But no matter what password I try to use it keeps giving me that error. I need these parental controls.
- cm2297Sep 22, 2015Aspirant
This is for the parental control.
I am trying to create this from the Netgear app that was downloaded to my pc. I am not opening a browser seperate from the app.
- ElaineMSep 23, 2015NETGEAR Employee Retired
- buckeyestargazeSep 23, 2015Star
Adding a special character to my password worked, so I was able to create a OpenDNS account with a password that contained a special character, capital letter, a number and is between 6-20 characters. I would like to note that nowhere on the instructions did it say that all of this was needed, just a password between 6-20 characters.
