cm2297
Sep 21, 2015Aspirant
Live parental controls fails to setup
I have a N900 wndr4500v2. When trying to set up the parental live controls I make it as far as putting in user name and a password. I hit enter and it comes back with the password not being long enou...
- Sep 23, 2015
Can you verify if using a special character and capital letter for password will help you guys pass this registration?
Looking forward to your responses.
nortbrooknz
Oct 20, 2015Aspirant
Hi Moderator,
Having trouble logging in to LPC through genie....opendns account, says that I may not be connected to the internet... which is not the case.
I have the latest firmware update installed.
Modem model is DGND3700v2
Any suggestions?
ElaineM
Oct 20, 2015NETGEAR Employee Retired
Vaquero Our engineers are working on this and we will soon release a fix for it.
nortbrooknz Do you have the latest Genie App installed? Try to uninstall and reinstall the app.
By the way, are you using the Genie on a computer or an iOS/Android device?
Did you try using a different computer or device?
Let us know what happens.
