cm2297
Sep 21, 2015Aspirant
Live parental controls fails to setup
I have a N900 wndr4500v2. When trying to set up the parental live controls I make it as far as putting in user name and a password. I hit enter and it comes back with the password not being long enou...
- Sep 23, 2015
Can you verify if using a special character and capital letter for password will help you guys pass this registration?
Looking forward to your responses.
MikeG3
Oct 28, 2015Tutor
When changing the OpenDNS password (I had six numbers as my old password), I was able to change it to an acceptable one with upper / lower case letters, a number and a symbol.
It does not work on my Genie Android app, nor does the application install on my Windows 10 machine properly (error when trying to open it).
ElaineM
Oct 28, 2015NETGEAR Employee Retired
MikeG3 Are you trying to login using the bypass account? Or you're just logging in using your OpenDNS account?
What's the error? Kindly post a screenshot.
- MikeG3Oct 28, 2015Tutor
When I try to login to the Open DNS account, it keeps asking me over and over to login on the Android App. The PC application simply crashes immediately.
- ElaineMOct 29, 2015NETGEAR Employee Retired
Tried replicating this using an Android device and I was able to login.
Can you try to login using netgear.opendns.com?
See if you will get the same loop.
If it doesn't, uninstall and reinstall the Genie App on your android device.
There have been reports that some users are having problems running the latest Genie app version on their Windows 10 computers.
Our engineers are investigating on this, for now we suggest that you use an older utility.
- MikeG3Oct 29, 2015Tutor
Ok now I can suddenly log in with my android.
What user and password do I use for the link of the old utility you sent for the PC?
- EllenMOct 30, 2015Aspirant
Hello,
I am trying to set up an open dns account so that I can use the parental controls. I get to the screen that says,
Create as free OpenDNS account.
I enter in a user name, and a password. It keeps telling me,
"Invalid password. The password must be between 8 and 20 characters and contain one upper case, character, one lower case character, and one numerical digit. Allowed symbols are!@#$%^&*()."
I have tried various long passwords that contain letters, numbers, a special character and a capital letter and it won't let me get any further in the process. What can I do? Without the parental controls, the wifi router is not useful for me.
Thanks,
Ellen
Cancel the need and confusion expressed in my previous email.
I was able to set up an OpenDNS account using my cell phone, which I can log into using my computer.
That has been a very frustrating and time consuming work around. I hope that my experience and my fix saves some other users some frustration and I hope that Net Gear fixes this problem.
Thanks,
Ellen
- ElaineMNov 02, 2015NETGEAR Employee Retired
Hi EllenM,
Can you verify if you could setup OpenDNS on the PC?
Let me know if you're still having the same problem.Looking forward to your response.
**Edit: Can you tell us how many characters you have used on the Windows Genie?
If you are still having difficulty, can you verify if it will allow you to set the password with a minimum of 13 characters.
