billjfr
Sep 15, 2015Aspirant
Local network with 2 routers and 2 internet access. How to choose which internet access is used ?
Hello I have a configuration at home with 2 Netgear routers and 2 internet access : - 1 ADSL modem/router series 1000 (local address 192.168.0.1), with ADSL connection enabled, - 1 router se...
- Sep 18, 2015
I thought for sure that this was going to be a question about load balancing across two Internet connections. Instead your questions are much more straightforward. The answer to both questions is, "Yes."
