Answerplease
Oct 13, 2019Aspirant
Locked out of c6300 router
Log into 192.168.0.1 the login popup comes up, use the admin and password and it says it does not recognize it. The recovery screen eventually pops up and gives me the EXACT username and password I ...
- Oct 13, 2019
Its the damn browser.. firefox won't allow you to log in for some reason. Had to try Edge ( which sucks) and it worked)
Answerplease
michaelkenward
Oct 14, 2019Guru - Experienced User
Firefox was probably remembering an old password.
Try the Firefox lockwise extension.
- AnswerpleaseOct 14, 2019AspirantFirefox was not remembering an old password I don't allow browsers to do that. I was able to access it through FF a few months ago.. they must have pushed an update either for the router or FF that screwed up the ability.. I find it odd though that I can access it through edge.
- michaelkenwardOct 15, 2019Guru - Experienced User
Answerplease wrote:
they must have pushed an update either for the routerYou can probably rule out that one. The C6300 is a cable modem/router – so your message is really in the wrong place – which means that it is down to the Internet service provider to push out updates and most ISPs don't bother with that.
Here's the official line:
If your firmware is outdated, you cannot manually upgrade your cable modem’s or modem router’s firmware. You must contact your Internet service provider (ISP) to upgrade your firmware.
You could check with your ISP, but they probably won't know what you are talking about.
Answerplease wrote:
FF that screwed up the ability.. I find it odd though that I can access it through edge.They have certainly been messing around with Firefox. I have also seen strange behaviour. It hasn't kept me out of my router, but I have had to mess around with permissions. At least they are easier to get at now.
