MaxiBelas
Sep 07, 2021Follower
Locked out of my Netgear Router
Chrome typically saves my passwords, but for some reason it won't work for my router. The security questions aren't working either. I went to their website and you can only get support by registeri...
Sep 07, 2021Guru - Experienced User
1. what router do you have?
2. you don't need to register to download firmware updates. go to netgear.com/support/ type in your actual model number. it'll take you to manuals, firmware, etc. you can download it from there.
3. If you don't know the log password to the router and don't know the security questions (or didn't set them up, it still asks but there isn't a correct answer), then you'd need to factory reset to get back in. Push and hold reset for 7-15 seconds while its powered on. that should get you back to the defaults.
