kisayquri
Mar 10, 2022Follower
Locked out of my Netgear Router
Chrome typically saves my passwords, but for some reason it won't work for my router. The security questions aren't working either. I went to their website and you can only get support by registering (apparently) or paying them $50, but it says I have already registered. I'm just trying to download the recent security update.
Does anyone know what they require for their passwords (Special characters, caps, and all that)? I can't figure this out and Netgear's "support" is pretty useless. Thanks.
1 Reply
Problem with the security question is that if you don't know the answers or didn't set them up, it still asks. If there isn't a correct answer, it just circles. If you're in that situation, you'd need to factory reset to get back in.
Push and hold reset for 7-15 seconds on the reset button and then follow the reinstall guide.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
