hkrieger
Dec 20, 2021Follower
Log in to Netgear 6080
I use to be able to log into the netgear router via www.routerlogin.net with the standard id of 'admin' plus my password. It no longer works. What's going on?
michaelkenward
Dec 22, 2021Guru - Experienced User
hkrieger wrote:
What's going on?
That's anybody's guess.
While you are digging out some answers to the question from plemans try this:
If you cannot login to your router | Answer | NETGEAR Support
wcalifas
Dec 23, 2021Prodigy
You can always do a hard reset but it will put your router back to factory default.
