GrubLeo
Sep 26, 2022Aspirant
Login refused by R6400V2 after firmware upgrade.
Hi all, this is not a new one, I think. After updgrading to 1.0.4.128 I can't log into the router (connection refused by router: tried ip address and www.routerlogin.net and several browsers). Res...
Sep 26, 2022Guru - Experienced User
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
GrubLeo
Sep 27, 2022Aspirant
Hi, thxs for the suggestion.
Answer: no factory reset.
As I didn't see this issue coming I didn't make a backup just before upgrading.
Drawback of the reset is I have redo all setting.
Nothing in the release notes of this update btw suggested a factory reset.
I'll check your link.
- FURRYe38Sep 27, 2022Guru - Experienced User
I recommend after you reset and setup from scratch, make a back up configuration to file for safe keeping. Saves time if a reset is needed:
- GrubLeoSep 27, 2022AspirantJust checked the link.
I obviously can't do the reset via the login page.
I did push the little reset button but that didn't change the issue.
Should the reset button be pushed for some time to do a factory reset?
I don't see such a remark in the manual.- GrubLeoSep 27, 2022AspirantMy last backup is about two years ago and I change some stuff in between.
I agree on making a new one once I am done.
