richardmumford
Feb 22, 2017Aspirant
login to www.routerlogin.net fails when using factory password and admin?
When I attempt to login using to www.routerlogin.net and enter admin and the factory password, it fails. My wifi printer now gets a failed password message. I have done a reset on the router, I can...
- Feb 27, 2017
Well I hate the simple solution that makes me an idiot but if helps others...
1.) The factory password to enter the router settings is password, the factory password to connect to the router is whatever is printed on the label at the bottom of your router.
2.) Remember that the password to use your wifi is case sensitive. The little keypad on the printer has it's own little way of enabling caps, numbers and lower case letters.
ElaineM
Feb 24, 2017NETGEAR Employee Retired
Welcome to the community, richardmumford
How did you reset the unit? I suggest that you use a paper clip when pushing the reset button.
How do I perform a factory reset on my NETGEAR router?
After resetting the router, reconfigure the settings and input your desired password.
richardmumford
Feb 24, 2017Aspirant
I used the sharp end of a pen and felt the button go down.
Good suggestion, I will try again with a paper clip.
I'm ok with the factory password but for some reason my wireless printer fails to gain access and says password failed.
- richardmumfordFeb 24, 2017Aspirant
Perhaps I also need to complety uninstall the Epson printer and re-install.
- ElaineMFeb 24, 2017NETGEAR Employee Retired
Yes, try that route and let us know any update.
