austinflint's avatar
austinflint
Follower
May 01, 2017
login to www.routerlogin.net fails when using factory password and admin?
To make a long story short, my roomate just moved out and he had control over the routers admin login. He also had an additional router plugged in to my router for some odd reason. He also disabled t...
  • wcalifas831's avatar
    May 01, 2017
    press the reset pin hole on the back of the router with a paper clip for 30 seconds and it will go back to default settings.
