sasha123
Dec 03, 2020Aspirant
Looking for suitable device
I don't have enough knowledge about what device I am looking but I got a tip to look here. I live on a yacht and I am looking for a device which works with a sim but have a broad area of receptions wh...
Dec 03, 2020Guru - Experienced User
You have to keep in mind that its only going to work where you get cellular reception.
If you're looking for a hotspot, there's the MR5200 being released with 5g
https://www.netgear.com/home/products/mobile-broadband/mobilerouters/mr5200.aspx
- sasha123Dec 03, 2020AspirantDoes it work with orbi ac or something similar?
- plemansDec 03, 2020Guru - Experienced User
sasha123 wrote:
Does it work with orbi ac or something similar?Does the hotspot?
Not sure exactly what you're asking here?
- sasha123Dec 04, 2020AspirantAs I mentioned I am looking for a solution wich can support an area of approximately 20m of receptions so my neighbors could connect to it too and still get a good wifi connection.
I saw another product (netgear orbi 4g lte) which works with orbi ac to solve this same problem (of distance from the router and walls in between), and as I said I am looking for something which works with 5g and only the product you shared here works with it but the question if it would work with wifi range extenderes or not like the nethear orbi 4g lte
