Hal2001
Jun 13, 2020Aspirant
Looking for the best router for my slow DSL service
My existing router produced a max of 7.5 speed which is fine for all I do with it. but the router is about shot constant flickering of lights and speed test shows 1 or less.
- Jun 15, 2020
We still do not know how fast your DSL service is. " a max of 7.5 speed" tells us not much. So it is hard to tell where there might be any roadblocks on your network.
If you have a slow Internet service, no amount of fancy hardware will suddenly make it go faster.
Hal2001 wrote:
A saleman sold me an ORBIWhole home wifi system dual band wifi with Ori RBR10 router and Orbi satelite. RBS10. when I got it home I read the box (didn't have my glasses in store) and it says I need a high speed connection which I certainly don't have.
"High speed" can mean anything. I have an Orbi system working with DSL Internet service.
The advantage of Orbi is that it gives you a good and, for most people, easily controlled local wifi service for everything you and the family play with.
But the Orbi does need a modem in front of it.
Hal2001 wrote:
It is a Centurylink C100Z.
If you mean Zyxel C1100Z – I can't find Zyxel C100Z – that is a modem/router. You can get it to work in "bridge mode" with the Orbi, but I doubt if it will provide faster Internet. If you want to stop paying the monthly fee, then you need to buy a modem to go with the Orbi.
The bottom line is that the only way to get faster Internet is to take out a subscription for a faster service. But that may not be available where you are.
Hal2001
Jun 14, 2020Aspirant
Thanks for your reply. My home network is run by the router I got from my service provider, but I would like to upgrade to the best router my slow DSL connection. A saleman sold me an ORBIWhole home wifi system dual band wifi with Ori RBR10 router and Orbi satelite. RBS10. when I got it home I read the box (didn't have my glasses in store) and it says I need a high speed connection which I certainly don't have. So my primary question is...will this even work? and will it help...or should I return it for something simpler. Spent over $100 dollars for it. I bought a repeater a few years ago and could not even make it connect to the router...I've been renting the router from my phone company for $10 /month. It is a Centurylink C100Z. Thank you for any suggestions..I haven't opened the box yet as I may need to return it...Hal
michaelkenward
Jun 15, 2020Guru - Experienced User
