sc_wifi
Jan 22, 2022Aspirant
Looking for wireless Router
Home is having fibre cable to the premises connected through OptiComm network (Melbourne, Australia) and looking for to use only one Wireless Router device rather using multiple WiFi extenders (just ...
michaelkenward
Jan 23, 2022Guru - Experienced User
Try plugging your needs into the filters on the product pages:
Wireless Routers for Home | NETGEAR
and
Orbi: Whole Home WiFi System for Better WiFi Everywhere | NETGEAR
Then check back here for reports on the things you are considering, but remember that people turn up in this community with problems, not compliments. So look at reviews on Amazon, for example.
sc_wifi
Jan 23, 2022Aspirant
I need assistance in choosing the product for my home.
The Filters you specified doesn't help much. It says WiFi Range for example up to 1500 sq ft but how we know whether it is 1500 sq ft is circular range from WiFi Router ? or something else ?
- michaelkenwardJan 24, 2022Guru - Experienced User
In which case, you are probably asking in the wrong place.
Try visiting a local dealer who can discuss your needs. Or ask a friend what they use.
