SHO_GuN
Sep 16, 2017Aspirant
Losing Ability to Connect to Interface
Everything is fine after a reboot, but within a day or two when I click on "Attached Devices", instead of showing the attached devices that area of the page shows some sort of error. The next thing to happen within another day or two is I lose the ability to connect to the interace at all. All devices that I have stay working even when this happens.
I have tried a reset and there is no change in this behavior.
Up until 6 months ago I shut down my modem and router each night so they started each day with a fresh boot. I now have a couple devices that need 24 hour internet access so they now stay on 24 X 7. The number of devices that are connected have crept up to around a dozen.
Is something wrong with the router or am I just asking too much for such an old device?
If the latter, any suggestions for a replacement? I am overwhelmed by the selection out there.
Thanks
Kindly check your inbox.
- SHO_GuNAspirant
Delved a little deeper into this...
Reset router, re-uploaded firmware and instead of restoring from backup, entered all settings from scratch.
Lost contact with the interface within an hour.
Probably going to try non Netgear firmware just for the fun of it.
Still would like replace model advise. If I am in fact overloading it, should the V2 solve my problem?
Thanks
- SHO_GuNAspirant
This is a known but never acknowledged nor fixed bug: Netgear WNR3500L - Attached Devices Problem
I guess I never noticed it before due to the daily reboots.
- ElaineMNETGEAR Employee Retired
