Ametuer
Feb 19, 2021Follower
loss of signal
We lose our signal (cable) 3 or 4 times a day. I remove the power supply to the router and it will reset. I don't know or how to tell if I have a problem with the router or the incoming signal? Is...
Feb 20, 2021Guru - Experienced User
If you take a screen snip of the cable connections page and the event logs, that helps us to check the line.
https://kb.netgear.com/30008/How-do-I-obtain-the-event-logs-from-a-NETGEAR-cable-modem-modem-router
