tzanzinger
Jan 01, 2021Aspirant
lost internet connection rbr50 v2
Good afternoon, First posting in this forum, any help appreciated. Yesterday evening without any change to the setup we completely lost our internet connection. The orbi router is connected via a...
antinode
Jan 01, 2021Guru
> The orbi router is connected via a ziggo modem [...]
Has your "a ziggo modem" a maker and model number? Is it really only
a "modem", or is it a modem+router?
> When looking into the setup the orbi router was not configured as an
> AP. Tried to change that [...]
Why? Was there some actual problem which you were trying to solve?
> [...] DHCP did not work.
If the RBR50v2 is your only router, then you should leave it as a
router. Configuring it as a wireless access point would disable its
DHCP server, and would probably limit you to using one client device.
- tzanzingerJan 02, 2021AspirantThanks for your willingness to get me on a path for resolving this issue.
I took a very different approach as i could not spare any more time and bought google nest wifi. It was pretty much p&p and got us us online again. Now i have a spare setup for the future...
Again, your efforts are really appreciated.
