rocksterman
Aug 29, 2017Aspirant
Lost IP address (on Android Turbo phone) for WiFi connection
I disconnected from my WiFi because my phone security app (McAfee) said that hackers were trying to intercept my data. When I tried to re-connect, I get a WiFi Connection Failure message. After some s...
- Aug 30, 2017I finally found the problem. McAfee security app had sent a message saying that hackers were trying to intercept my data & asked if I wanted to disconnect. I disconnected. What I came to discover was that McAfee, as a result of the warning, had set (on my Wi-Fi security settings) to always disconnect from my Wi-Fi (considering it a permanent threat I suppose). I removed the Wi-Fi from McAfee's "remembered Wi-Fi" list (thus getting rid of the disconnect setting) & then re- connected to the WiFi on my phone & the problem was solved.
ElaineM
Aug 30, 2017NETGEAR Employee Retired
Welcome to the community, rocksterman
Your phone should automatically get an IP address when you successfully connect to the wireless router.
Try to restart your phone and reconnect to the wireless network name.
Make sure that you have the correct wireless password.
rocksterman
Aug 30, 2017Aspirant
- ElaineMAug 30, 2017NETGEAR Employee Retired
Glad you were able to sort it out.
Thank you for the update!
