rocksterman
Aug 29, 2017Aspirant
Lost IP address (on Android Turbo phone) for WiFi connection
I disconnected from my WiFi because my phone security app (McAfee) said that hackers were trying to intercept my data. When I tried to re-connect, I get a WiFi Connection Failure message. After some s...
- Aug 30, 2017I finally found the problem. McAfee security app had sent a message saying that hackers were trying to intercept my data & asked if I wanted to disconnect. I disconnected. What I came to discover was that McAfee, as a result of the warning, had set (on my Wi-Fi security settings) to always disconnect from my Wi-Fi (considering it a permanent threat I suppose). I removed the Wi-Fi from McAfee's "remembered Wi-Fi" list (thus getting rid of the disconnect setting) & then re- connected to the WiFi on my phone & the problem was solved.
rocksterman
Aug 30, 2017Aspirant
ElaineM
Aug 30, 2017NETGEAR Employee Retired
Glad you were able to sort it out.
Thank you for the update!
