jerrymac
Nov 20, 2021Aspirant
lost my wifi R6080
I unpluged everything of my netgear r6080 while moving it and now not sure how to plug it back in? It looks right but the internet light is orange. I dont know much about these things. I'm old and need a kid here.
I went out a got a google nest and unpluged it. working fine now
Did you power OFF the ISP modem and router for 1 minute then back ON with the modem first then router?
Besure the LAN cable is plugged into the WAN Port on the router from the ISP modem.
- jerrymacAspirant
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- jerrymacAspirant
I tried that still didn't work
- Chami925AspirantBought this and my internet light is red went they each plug changed them switched them around and my tv still be buffering how to fix this problem. Please help
Chami925 wrote:
Bought this and my internet light is red went they each plug changed them switched them around and my tv still be buffering how to fix this problem.Apart from having a hard time making sense of that description, you have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one, especially as it is marked as SOLVED.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.In the meantime, manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
Begin with the Quick Start/Installation Guide.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
