00sivan
Sep 18, 2022Aspirant
Lost Password During Restore
I have an R6300v2 and I backed it up so that I could factory restore for troubleshooting. Having logged in after the factory restore, I set the new password and it overwrote the password in Edge. The...
- Sep 18, 2022
Never mind. I found the old password was still saved in another browser.
Sep 18, 2022Guru - Experienced User
And you might save off a new backup config that should now have the corrected or new admin password.
00sivan
Let me explain why a new backup doesn't work.
Create a backup -> Factory Restore -> Forced to Set a password (does not populate from browser) -> Perform troubleshooting/testing -> Restore from backup -> Edge Saved password no longer matches config file
Essentially, config files don't work with MS Edge unless you turn off automatic password storage. It's likely this could affect Chrome users in the near future if automatic password saving is enabled.
