jonp912
Mar 10, 2021Follower
Lost Password
Hi, I have a WN300RPv3 extender, the password is lost and I need to connect a new device (Dell PC) how can I connect the PC without a password or how do I reset/recover the password?
Mar 10, 2021Guru - Experienced User
You can log into the extender from a device that does connect to it. Then you can view/change ssid/password.
If you don't remember the login to the gui though, then you'd need to factory reset to get back to defaults.
https://www.netgear.com/support/product/WN3000RPv3.aspx
