amyhan
Oct 30, 2015Aspirant
Low speed issue with N600 WNDR3400 router and Arris 6141 modem
I have a Comcast Xfinity connection that gives me download speeds of close to 70 Mbps.With a wired connection directly from the modem I get the high speeds .However, with the WiFi connection through ...
- Oct 30, 2015
I change the belkin router then everything is ok
TheEther
Oct 30, 2015Guru
What Wi-Fi device(s) do you have? If it's a smartphone, please provide the model number. If it's a PC/laptop, please provide the model number of the Wi-Fi adapter.
Do you have WMM enabled? If must be enabled for higher Wi-Fi speeds.
Did you try changing Wi-Fi channels?
- amyhanOct 30, 2015Aspirant
Iphone 4s and toshiba,WMM is on.I tried changing the channels.It showed no significant change in the speed.thx
