amyhan
Oct 30, 2015Aspirant
Low speed issue with N600 WNDR3400 router and Arris 6141 modem
I have a Comcast Xfinity connection that gives me download speeds of close to 70 Mbps.With a wired connection directly from the modem I get the high speeds .However, with the WiFi connection through ...
- Oct 30, 2015
I change the belkin router then everything is ok
TheEther
Oct 30, 2015Guru
IIRC, the 4S is a single dream, 2.4 GHz only, 802.11n Wi-Fi device. As such, the best case link speed is about 72 Mbps, with a real world throughput in the low to mid 30s Mbps. However, Netgear routers are configured to use long preamble, so max link speed drops to 65 Mbps, with a corresponding drop in throughput. Note: This assumes 20 MHz channels, which the router will use when other Wi-Fi networks are nearby.
All this translates to say that 25 Mbps is probably not that unreasonable. You may eek out a little extra speed by switching to short preamble, but that's about all you can expect out of a 4S.
amyhan
i have a iphone 6s,too,i cant get high speed,I have a Comcast Xfinity connection that gives me download speeds of close to 70 Mbps.With a wired connection directly from the modem I get the high speeds .However, with the WiFi connection through the router I get the download speed (~25 Mbps).how to do it?
- amyhanOct 30, 2015Aspirant
May i have to buy a new one?
