ginad
Feb 27, 2017Aspirant
mac address filtering how do I add a Mac address for my printer
I tried searching but not being very technical, can't quite find a solution. I hope one someone in the community could help me please. I just installed the AC750 router and works perfectly fine w...
- Mar 02, 2017
Hi - thanks for your replies.
I was able to figure it out, perhaps accidentally but it works now.
I pressed the WPS reset button (not sure what it means), I had to re enter the ISP details again for the internet, but then the printer just started working again.
Cheers, Gina
michaelkenward
Feb 28, 2017Guru - Experienced User
Which AC750? Netgear makes several. AC750 is a wifi standard.
Find the model number on a label somewhere likes this:
