bookat's avatar
bookat
MAC addresses on my iOS devices do not match those listed on my Netgear AC1200 R6230 router
I got a Netgear R6230 a couple of days ago and went to the Advanced screen to see my network's attached devices. I noticed that the MAC addresses on all my Apple devices (iPhones & iPads) were different from those listed on the router's Attached Devices screen. Why is that and which are correct?
  • > [...] the MAC addresses on all my Apple devices (iPhones & iPads) were
       Recent iOS update?  Where did you get "the MAC addresses on all
    [your] Apple devices"?
    > [...] Why is that [...]
       It's a feature.
    > [...] which are correct?
       "Both" or "It depends".  Define "correct".
          https://support.apple.com/en-us/HT211227
       It's a feature.
    • bookat's avatar
      bookat
      Thanks so much! Had no idea about iOS 14 using private MAC addresses for each wifi network. Interesting--and much appreciated.
