CRobles
Mar 16, 2023Aspirant
Mac cant read readyshare HD AC1750
Hello, I recently bought a western digital mybook external hd. I reformatted it to ntfs to make it easy on my wife who is a windows user. My macbook has ntfs for mac installed so reading and writing ...
michaelkenward
Mar 17, 2023Guru - Experienced User
Which Netgear device do you own?
AC1750 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
- CRoblesMar 17, 2023AspirantHello it is an R6350
- michaelkenwardMar 17, 2023Guru - Experienced User
I should have asked about the firmware version ans the modem/gateway/ONT between the router nd the Internet.
Then there is this:
Search - NETGEAR Communities – readyshare mac
