CRobles
Mar 16, 2023Aspirant
Mac cant read readyshare HD AC1750
Hello, I recently bought a western digital mybook external hd. I reformatted it to ntfs to make it easy on my wife who is a windows user. My macbook has ntfs for mac installed so reading and writing ...
michaelkenward
Mar 17, 2023Guru - Experienced User
Which Netgear device do you own?
AC1750 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look at the label on the device for the model number.
CRobles
Mar 17, 2023Aspirant
Hello it is an R6350
- michaelkenwardMar 17, 2023Guru - Experienced User
I should have asked about the firmware version ans the modem/gateway/ONT between the router nd the Internet.
Then there is this:
Search - NETGEAR Communities – readyshare mac
