sgmstr
Jan 30, 2022Aspirant
Mac Devices Connect to Wifi, but Not Internet
R6400V2 (AC1750) with Firmware V1.0.4.122_10.0.95. Mac devices not connecting to Internet (only connect to Wifi Router). Non-Mac devices connect to Internet awith no problem. It happens randoml...
sgmstr
Thanks again for replying here. It seems so since all were good before updating firmware, so yes, I'm leaning towards downgrading it.
Do you just upload the older firmware into the router under "Advanced" ->"Administration" -> "Update". (See screenshot) Anything i should look out for?
my devices do not have ethernet cable port so it'll all have to be done wireless.
Jan 31, 2022Guru - Experienced User
Correct you'd follow the route and upload the older firwmare to it.
Works pretty well.
the only thing to look/check for is to disable auto-updates so it doesn't revert back.
