wadinho's avatar
wadinho
MAG IPTV Set-Top Boxe fails to connect
Hi guys,   I need help because I am getting very frustrated with this situation. I have just bought a MAG 254 which is an IPTV box basically to watch TV. I have tried to set up wifi connection but ...
  • TheEther's avatar
    Oct 01, 2016
    Be sure you are entering the Wi-Fi password correctly.  Wi-Fi passwords are case-sensitive.
    Other than that, make sure the MAG 254 is using the same form of Wi-Fi security as the router (e.g. WPA, WPA2).
