wadinho
Oct 01, 2016Aspirant
MAG IPTV Set-Top Boxe fails to connect
Hi guys, I need help because I am getting very frustrated with this situation. I have just bought a MAG 254 which is an IPTV box basically to watch TV. I have tried to set up wifi connection but ...
- Oct 01, 2016
Be sure you are entering the Wi-Fi password correctly. Wi-Fi passwords are case-sensitive.
Other than that, make sure the MAG 254 is using the same form of Wi-Fi security as the router (e.g. WPA, WPA2).
TheEther
Oct 01, 2016Guru
wadinho
ok it is working...I have changed my password and removed the $ sign from my previous password
thanks a lot guys for your help! I hope this thread will help other people in th future
cheers
