astaib
Oct 02, 2022Aspirant
Make a bridge on R6120
Hi there, Thank you in advance for your help. I consulted the topics that could have helped me but because of my lack of knowledge, i haven’t been also to solve my problem. so I ask you to speak t...
michaelkenward
Oct 02, 2022Guru - Experienced User
astaib wrote:
I have to move my R6120 and need it to be where my TV decoder is, but when I plug my R6120 into the RJ 45 that comes from the box (the internet box is in another room quite far away and with very thick walls) and I connect my TV decoder to one of the R6120's RJ45 outputs, it does not work.
Does this mean that your R6120 is not connected to the "internet box"?
What is this internet box? Make and model?
What sort of Internet connection do you have? The most common is with a cable to the outside world that feeds into a modem at your end. That feeds your router.
Your router must have an Internet connection to work. If the only way to connect is through the Internet box, then it won't work without that connection.
After reading some subjects, I read that it was necessary to either pass the R6120 as an access point, which I did but it still does not work. Or else I read that I had to configure one of the R6120's RJ45 ports as a "bridge".
An access point needs a wired connection from modem (Internet box) to router.
The "bridge" word can mean various things, depending on the device. For a router this can be a "wireless bridge" between two wifi devices. That usually refers to two routers or a modem/router and a router.
Not all routers can work as a wireless bridge. I see no sign that the R6120 has that feature. It is a pretty basic device near the bottom of Netgear's range. It has a slow Ethernet connection. At 100 Mbps it is slower than many Internet services. If you speed is supposed to be faster than that, you are wasting money.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.
astaib
Hello,
Thank you very much for your help.
A description of my installation is:
-Internet from the grid via optical fiber to the internet box NB6VAC-FXC-r1.
-3 port of the box are used with Ethernet cable to printer, computer…
-1 port is linked with a long Ethernet cable to another part of the house where my “problem” is.
-the long Ethernet cable comes to the netgear.
-the wifi of the netgear is working fine pour phone, laptop…
-The Ethernet port of the netgear are working well for laptop, but not for the tv box (this box is provided with the internet box described before from my internet provider).
Please note that when I plug the long Ethernet cable directly to the tv box it is working.
The red of the tv box is DEC FIX STB7.
Thank you
Thank you
- michaelkenwardOct 02, 2022Guru - Experienced User
-the long Ethernet cable comes to the netgear.This suggests that you have a router sitting in front of a router.
Google seems to agree with that because the NB6VAC-FXC-r1 take me to a pic with four ethernet ports on the back. Does it also do wifi?
If I am right, you have two routers in the network. That's a recipe for chaos.
What is Double NAT? | Answer | NETGEAR Support
The simplest solution would be to put the R6120 into wireless access point mode. (Look it up in the manual.) Then plug the connection from the WAN port on the R6120 into the NB6VAC.
That leaves the NB6VAC-FXC-r1 to handle the router side of things. The R6120 can then handle anything you connect to the other LAN ports, like the TV, and the wifi from the Netgear.
Be warned, though, that the R6120 is slow. Cable Internet should be a lot faster than 100 Mbps. That won't matter for the TV, but the wifi will not be as fast as it might be.
The good thing there is that the Ethernet ports on the NB6VAC will almost certainly be 1000 Mbps. So your PCs and other things won't get slowed down by the R6120.
- astaibOct 02, 2022AspirantHello,
Thank you very much for that.
Yes the NB6VAC-FXC-r1 has 4 Ethernet and wifi, but the wifi is not passing through the walls to be visible where the netgear is.
I tried doing AP but it didn’t work, maybe I made something wrong. I will try again tomorrow because I’m not at home anymore.
I will keep you posted.
Thanks again.
Arnaud.- michaelkenwardOct 02, 2022Guru - Experienced User
astaib wrote:
I tried doing AP but it didn’t work....What happened when you did it? The timing is important.
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
