FG
Jul 10, 2017Aspirant
Make a router just a wireless access point
One of my WAP took a dirt nap this morning. I have Netgear wireless router WPN824 V2. Can I turn this router into just and wireless access point? What should I turn off? Disable the UPnP, tha...
- Jul 10, 2017
Yes, disable DHCP and whatever else you don't want running on the router. When configure as an AP, you will need to move your uplink to a LAN port.
RE: not being able to connect to the router after changin IP address and disabling DHCP. You would need to cofigure your laptop network card in the same subnet as the AP (say 192.168.116.254 255.255.255.0) if you wnated to connect to it, off thwe network. So, it looks like you are good to go. If you can, turn off UPNP at all costs.. Portfowarding would be a better option with this home router stuff..
FG
UPnP is on by deflaut. I don't need.
What did you mean turn off at all cost.........bad to have on....security issus?
Should just get an new AP and toss this router, I'm I trying to squeeze a nickel from a dollar?
Under the attached devices tab, it shows most of devices on the network, even though I have "use router as DHCP server" disabled. Should I worry about that?
What is the current standard for wifi security.....WPA2-PAK [AES] ?
netwrks
Jul 10, 2017Master
UPnP can be exploited easily. If you don't need it, turn it off, set up port forwarding on your router. Connected devices is a list of the devices on your network. Nothing to worry about there. That is what you would use to see what is on your network. So, make sure you use strong router logins and strong wireless passphrases for your wireless.
