NandoM
Dec 03, 2017Aspirant
Making 2 routers into 1.
So I've got 2 routers as you can see on the picture below.
For the people that don't know a steam link needs to be in the same network as the pc you want to run it on to work.
So my problem is my gaming pc is upstairs and I need to get the router from upstairs into the same network as downstairs to make my steam link work. How can I do this?
My upstairs router is a model MNDR3700v4
My downstairs router is a model R7000(nighthawk)
- Enable Access Point (AP) mode in Advanced settings. Then reboot the gaming PC to ensure that it picks up a new IP address.
- NandoMAspirant
Does this work when one router isn't connected to the other one directly? (as you can see in the picture)
- It looks like they are connected to each other through a switch or Powerline connection. That's fine.
