CBanse
Oct 06, 2017Aspirant
Manually turning off wi-fi messes up turning on wireless signal by schedule.
I programmed my AC1450 to shut off wi-fi at 11pm and turn on at 6 am daily. It works as programmed...as long as I do not manually press the wi-fi on-off button on the side of the unit. If I do turn i...
- Oct 26, 2017
Per router specs according to our engineers, pushing the WiFi button takes precedence.
So, the scheduling is ignored once you push the on/off WiFi button.
CBanse
Additional info. My issue applies only to the 2.4GHz radio. The 5 GHZ radio is turned off as I do not have any devices that operate on 5GHz.
ElaineM
Oct 09, 2017NETGEAR Employee Retired
Welcome to the community, CBanse
Will you experience the problem if you downgrade the firmware version of the router?
Try to downgrade the firmware to 1.0.0.34.
- CBanseOct 10, 2017AspirantI will try that and report back in a few days. Thanks for your response.
- CBanseOct 12, 2017AspirantI changed the software version to 1.0.0.34_10.0.16. Tested it for two nights. Manually turning off the router's wi-fi before scheduled shutdown continues to result in wi-fi not turning on as per the schedule. Any other suggestions?
