CBanse
Oct 06, 2017Aspirant
Manually turning off wi-fi messes up turning on wireless signal by schedule.
I programmed my AC1450 to shut off wi-fi at 11pm and turn on at 6 am daily. It works as programmed...as long as I do not manually press the wi-fi on-off button on the side of the unit. If I do turn i...
- Oct 26, 2017
Per router specs according to our engineers, pushing the WiFi button takes precedence.
So, the scheduling is ignored once you push the on/off WiFi button.
ElaineM
Oct 09, 2017NETGEAR Employee Retired
Welcome to the community, CBanse
Will you experience the problem if you downgrade the firmware version of the router?
Try to downgrade the firmware to 1.0.0.34.
CBanse
Oct 10, 2017Aspirant
I will try that and report back in a few days. Thanks for your response.
- CBanseOct 12, 2017AspirantI changed the software version to 1.0.0.34_10.0.16. Tested it for two nights. Manually turning off the router's wi-fi before scheduled shutdown continues to result in wi-fi not turning on as per the schedule. Any other suggestions?
- ElaineMOct 16, 2017NETGEAR Employee Retired
Let me check on other suggestions.
I hope others can jump in and verify if it's the same case for them.
- ElaineMOct 19, 2017NETGEAR Employee Retired
I suggest that you also register your device for us to log a case.
- CBanseOct 22, 2017AspirantI bought this used (at Goodwill). The receipt does not identify the product. It is likely out of warranty.
