CBanse
Oct 06, 2017Aspirant
Manually turning off wi-fi messes up turning on wireless signal by schedule.
I programmed my AC1450 to shut off wi-fi at 11pm and turn on at 6 am daily. It works as programmed...as long as I do not manually press the wi-fi on-off button on the side of the unit. If I do turn i...
- Oct 26, 2017
Per router specs according to our engineers, pushing the WiFi button takes precedence.
So, the scheduling is ignored once you push the on/off WiFi button.
CBanse
Oct 12, 2017Aspirant
I changed the software version to 1.0.0.34_10.0.16. Tested it for two nights. Manually turning off the router's wi-fi before scheduled shutdown continues to result in wi-fi not turning on as per the schedule. Any other suggestions?
ElaineM
Oct 16, 2017NETGEAR Employee Retired
Let me check on other suggestions.
I hope others can jump in and verify if it's the same case for them.
