taromir
Oct 25, 2021Aspirant
Mejor router para casa de tres plantas
Hola, necesito añadir un router conectado por cable al modem/router wifi que ya tengo de mi operador para poder replicar la señal wifi (mismo ssid) con mucha más potencia de señal para dar buena cobe...
Oct 25, 2021Guru - Experienced User
In inglese per favore
If you already have a wifi router singal and you want to extend this signal to the rest of the home, then a wifi Extender would be recommened.
https://www.netgear.com/home/wifi/range-extenders/
Something from this are should be reivewed.
For additional help and information on WiFi Extenders,
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
