quinn71
Nov 07, 2021Aspirant
MER support - RBK352
Hi. Before I buy, does the RBK352 support MER (dhcp option 61)? Will use in conjunction with a Draytek modem. Thanks
michaelkenward
Nov 08, 2021Guru - Experienced User
A good place to look for detailed stuff on specifications is with the documentation for the device.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
If that doesn't provide the information you need, by all means visit the black hole you were invited to dive down, but be warned that most users won't know about arcane details. So that might not get you much further.
I cab find no reference to any of that stuff in the documents. But might full text search may not be using the correct terms. "Option 61" seems to be something on DSL modem/routers and one or two other devices. No mention for the RBK352.
You may need to get to the people who make these things. Sadly, most of the people here are fellow users who don't have access to that sort of detail.
Apologies for the other less than helpful "go away" reply. response. It just wastes everyone's time.
quinn71
Nov 09, 2021Aspirant
Thank you
- michaelkenwardNov 09, 2021Guru - Experienced User
Hope it helps.
You might get more if you said why you asked the question.
Is it something required by your ISP? Or are you running something else that needs it?
