quinn71
Nov 07, 2021Aspirant
MER support - RBK352
Hi. Before I buy, does the RBK352 support MER (dhcp option 61)? Will use in conjunction with a Draytek modem. Thanks
quinn71
Nov 09, 2021Aspirant
Thank you
michaelkenward
Nov 09, 2021Guru - Experienced User
Hope it helps.
You might get more if you said why you asked the question.
Is it something required by your ISP? Or are you running something else that needs it?
